From @ttaveira on Tue Jul 05 2016 15:27:28 GMT+0000 (UTC)
I’m trying to do the same thing. If I understand correctly, ipfs.files.add requires a Bufferor Readable Stream (Node.js types). Are we able to use the js-ipfs-api without Node?
Also, is there any difference between ipfs.files.add and ipfs.add?
From @norzak on Mon Nov 21 2016 15:22:51 GMT+0000 (UTC)
ipfs-js is node.js only I guess. If we could not write/move/copy/delete files from web browser in a way, how would ipfs be useful to anyone other than showing static web pages.
From @VictorBjelkholm on Tue Nov 22 2016 12:01:11 GMT+0000 (UTC)
@aniket-kumar
You have two different ways of using the ipfs.files.add method. Either you define a callback like this:
ipfs.files.add([new Buffer('hello world')], (err, res) => {
// do something with res
Or use it with promises:
ipfs.files.add([new Buffer('hello world')]).then((res) => {
}).catch((err) => { /* handle err */ })
It’s mentioned in the readme over here: https://github.com/ipfs/js-ipfs-api#callbacks-and-promises
@ttaveira
Yes, it works in the browser as well. You have some examples here: https://github.com/ipfs/js-ipfs-api/tree/master/examples
No, it’s merely there to fulfill the interface we defined in https://github.com/ipfs/interface-ipfs-core/ while remaining backwards compatibility.
@norzak No, js-ipfs works in the browser as well. There are examples in the repository itself (here: https://github.com/ipfs/js-ipfs/tree/master/examples) and I’ve also made an example for passing around data you can check out here: https://github.com/VictorBjelkholm/js-ipfs-passing-data
I’m gonna close this issue, and refer to future readers to open up issues in the appropriate repository if you’re having any troubles with either js-ipfs or js-ipfs-api
From @Kubuxu on Tue Nov 22 2016 13:31:48 GMT+0000 (UTC)
We are leaving issues open in FAQ repo so they are more easily visible.
