Another trouble I am having with trying to use ipfs on brave via ipfs companion is this:
Trying to download a pdf file (1) via ipfs network isn’t resolving in anything. My ipfs companion currently has ~200 peers. Ipfs node type is “Provided by Brave (experimental)”. Use Automatic mode is disabled (I want to strictly use my own local node). Use Local Gateway is enabled. Use Subdomains are enabled.
However, the ipfs tab is just keep loading (waiting for localhost…) without actually downloading the pdf.
Pre-Post Edit: I was tinkering around the ipfs companion extension settings while using this. Is enabling/disabling Load DNSLink Sites from Custom Gateway setting can have an effect?
Can your PDF be downloaded by some other gateway like ipfs.io, using http? Can your Brave ipfs:// work on any files you know also work already via ipfs.io on http ?
Thanks for this feature! I’m currently having a little play with it and it seems really good!
I’m working on building a platform on top of IPFS just now, as we are still early and trying to stay stealthy we are running our own IPFS network with a custom set of bootstrap servers and a swarm key.
I had a little look through the config settings and I can see how to get access to the node to tweak that such as setting the new bootstrap servers. What I couldn’t spot was a way to load in a custom swarm key. I wonder if this is possible?
It would greatly simplify demos for our prospective users if we can tell them “just install brave and use this config”. We do manage fine using wss connections to a server just now but it would be really neat to have people running local nodes so they have their own local persistent cache, but also to remove the reliance on the in browser js-ipfs nodes and webrtc setup.
I understand this isn’t a primary use case, it would be super handy for us though.
Checked to download the same file on Firefox without ipfs. And Firefox is also on stuck on keep loading. Perhaps it’s a problem with the file’s availability on ipfs, rather than a fault on the Brave ipfs extension.
I haven’t tried downloading a pdf that I know of from ipfs network. I just started using ipfs!
I should have dug more before asking - if anyone else is trying to get the brave IPFS node to connect to a private network, you can find Braves copy of ipfs in ~/.config/BraveSoftware/Brave-Browser/brave_ipfs/, adding the swarm key there and updating the bootstrap servers in the config has allowed us to join the Brave browser node to our private network.
This is really awesome, well done!
Curiously this didn’t break braves ability to handle urls from the main IPFS network, I guess it is falling back onto the backup gateway.
Apart from the issue I mentioned before, one consistent thing seems to be, when I go to an ipfs link, is large drop-down in my internet connection. Other tabs in my browser, also other programs using the internet connection, lose their internet connection, while the ipfs tab keeps on the loading.
This is one of the reasons I disable QUIC … in some cases, I’ve experienced local flooding of UDP packets… My ISP also seems to be performing some type of traffic filtering/blocking.
After disabling QUIC, I can run multiple IPFS nodes per LAN host without too many issues.
To disable QUIC… modify the config file as follows:
All other things being equal, IPFS network interaction will be slower when QUIC is disabled.
However, I’ve had issues with UDP which result in IPFS becoming mostly non-functional. So, in my case it’s “slow” but functional or mostly non-functional.
A useful feature would be the ability to decouple the IPFS node with the gateway selection option.
I’d like to have Brave turn on and off a local IPFS node within the Browser directory structure that I can use to quickly add web pages as I browse the Internet… but then automatically view those pages on a public gateway of my choice without messing with IPFS Companion…
It would be good to have a pinning service selection option in the settings. Maybe partner with Pinata or something to have a drop down menu with “Pinata” and “custom”
So based on reading this thread, sounds like you’ve isolated the problem to where it’s either some network problem (like routers, ISPs, etc) or else the file just isn’t being served up by any gateways.
So pick some example file, like from the IPFS getting started guide, and make sure you can access it thru https+Firefox first, and then go to Companion next, and only once you have both those working, then move to your specific PDF file as the last step.
@ipfsme Maintainer of quic-go (the QUIC implementation used in IPFS) here.
There’s UDP blackholing on the internet, but it’s not very common. ~1% of connections, according to Google’s measurements.
I’d be interested in looking at QUIC traces from your node. Maybe we can figure out what’s going on. Could you run your go-ipfs with the environment variable “QLOGDIR=.” and share some of the qlog files that are generated with me?
Which entries/parameters are interesting or helpful?
zcat *.gz | jq [xyz]
I don’t believe my ISP is performing wholesale UDP blackholing… and my IPFS nodes generally work OK with UDP for a short amount of time. However, long running nodes tend to bog down and both my LAN as well as WAN connections slow considerably. Eventually I’ve had to bring down my whole Intranet infrastructure including routers and various file servers.
Once QUIC is disabled, all of the bogging down issues disappear… So, it’s definitely caused by running IPFS nodes with QUIC enabled. But, the logs might not show any issues until I have network problems. Perhaps my ISP is doing some sort of active traffic filtering or rate limiting on UDP… Perhaps running a couple of IPFS nodes looks like a DDOS attack from/to my IP…
