Creazilla.com is looking for a node.js developer to write backend for Creazilla’s online graphic design editor.
Key points:
- Knowledge of Node.js
- You have experience with MongoDB and with one of relational databases.
- You have experience with Fastify framework.
- You write clean code using TypeScript.
- Usually, you do tests with minimal line coverage of 60% for the backend.
Full remote. Part-time or full time. 15$ per hour with every 6 months revision.
