After I hosted my website in IPFS, it wasn’t showing some components and when I checked the console, it showed me the following errors:
[Error] Failed to load resource: the server responded with a status of 404 () (pets.json, line 0)
https://gateway.ipfs.io/ipfs/QmWzZ2x9tWHxRESmYVdktLGVGKqaFCyq2chkBrjZwMBjec/pets.json
[Error] Failed to load resource: the server responded with a status of 404 () (Adoption.json, line 0)
https://gateway.ipfs.io/ipfs/QmWzZ2x9tWHxRESmYVdktLGVGKqaFCyq2chkBrjZwMBjec/src/Adoption.json
Because I have added all my directory but I don’t know how to fix the issue
adin
December 16, 2021, 3:22pm
#2
The paths you listed are not associated with that CID https://gateway.ipfs.io/ipfs/QmWzZ2x9tWHxRESmYVdktLGVGKqaFCyq2chkBrjZwMBjec .
❯ ipfs ls QmWzZ2x9tWHxRESmYVdktLGVGKqaFCyq2chkBrjZwMBjec --resolve-type=false --size=false # flags passed to make the lookup a bit faster
QmY8hGfuWmnaUvBWUwnAcnvAUDfHE1LiduJ3LCqk4NWaJf LICENSE
QmbQxip7JFpRobjgepTukv3T7saPu6nJCfCA94Tw2ZoYGb bs-config.json
QmVy1ykpWetXoqjqjwGdhjDd6xTDwhyMBZHHPL5nRWwHNP build
QmYXHNayfwJtZ8j7nUMFKc3Th5ebDz74HLuVgFrF6Hpfdq contracts
QmZ1SKEoN8NwViTL665RYivuiv62br3UJqChneakxDKoGo migrations
QmQVqteEnQVy2siRxogWC9YppNLvXECVxQLgpAu8rezkhu node_modules
QmcJZXZMEdUZfAybVtDta2G5AvTeRnZ7Fs3fMewPZwxEW8 package-lock.json
QmY7Vo8SGD2cVVvaL8hARNSh1w22qpi6KapoMskDCVNzH5 package.json
QmcTrPp7SMmFqdzYV3Vn957M8B6kDtP5i5qqJFc3UFjZAV src
QmcyiQaZ3mFnfBXaXNmMzegxxQ3nLsSFkF12hWCuKRcWiW test
QmcHhhTdwFkj5YoPm4reQsoUdhgGaY4AVCkiYSRApeaHDX test.js
QmSjqJrQrvRr3Mu8G8DKkz59whmVEpFhiv1XPCqEeN5Qkz truffle-config.js
Note that pets.json doesn’t exist.
Also:
❯ ipfs ls QmWzZ2x9tWHxRESmYVdktLGVGKqaFCyq2chkBrjZwMBjec/src --resolve-type=false --size=false
QmQfwrATTrJc1aTN1dVu9K7nQ5rw67np8yg46EvAbqKEZw css
Qmb3fJpXVGvUnNeRLC3P5sTXMzjpf5zq4tKt9XjhtYFf1k fonts
QmQo4AjSx9JkNsHa3nRqxtryx6iGHmqGprhm2ic2MztW3Y images
QmRgLU31xJHNmGRXRxPdjG51kRmnYbQGWxYcBD7gtfH7Lm index.html
QmQ1vM2CdeDt1ZGAfxwML6PXPG2Hi6exvHdi6Hbhzv1kza js
QmZKHAuYoeAjHqfhi2jJaELDfMBj6dtydz7UsZv3BPaon8 pets.json
Found pets.json, but there’s no Adoption.json there.
Side note: I don’t think your data is reachable over the public internet (at least the only node I could find advertising QmWzZ2x9tWHxRESmYVdktLGVGKqaFCyq2chkBrjZwMBjec was unreachable).
You can use https://ipfs-check.on.fleek.co/ for some debugging to figure out if your peer (addresses available from ipfs id) and CID are going to be discoverable from your machine.
