From @mattseh on Sat Jun 18 2016 15:55:20 GMT+0000 (UTC)
If I have /ipfs/(some hash)/a/b/c , is there a way to turn a, b and c into multihashes in one call? This can be done one at a time with calls to object stat, but one call would be nice
Copied from original issue: https://github.com/ipfs/faq/issues/135
From @Kubuxu on Sat Jun 18 2016 16:55:35 GMT+0000 (UTC)
You can use:
~ ipfs resolve /ipfs/QmR1AeboA161SNxfSgRYtp264RucPVYcHLradx3kJP2f4o/trooper.jpg ✘
/ipfs/QmY3nJ4zW5j5dJ8LmNT9yF3Twp9dv5FP18rLf5kDXMBhYP
It will resolve recursively until single multihash.
From @mattseh on Sat Jun 18 2016 17:07:44 GMT+0000 (UTC)
I don’t mean a single result, I mean the multihash for every component of the path in one call, A, B and C.
From @Kubuxu on Sat Jun 18 2016 17:28:43 GMT+0000 (UTC)
Then no, there isn’t command like that, you would have to use some script.
