I’m following this: https://ipfs.io/ipfs/QmNZiPk974vDsPmQii3YbrMKfi12KTSNM7XMiYyiea4VYZ/example#/ipfs/QmP8WUPq2braGQ8iZjJ6w9di6mzgoTWyRLayrMRjjDoyGr/websites/README.md but where would I place the DNS TXT record when using a local machine?
Thanks!
Thanks!
You can get TXT records to work locally if you’re using dnsmasq, check out this example configuration: https://gist.github.com/m13253/c427f6825e938101189d#file-dnsmasq-conf-L637-L646
Without running a local resolver, I’m not sure you can.
Thanks, I’ll give this a try!
