There are two scenarios that I’m struggling to understand.
#1 Data Replication
Say I upload a file on my local node (ipfs add ..) and then, I execute ipfs bootstrap add … and ipfs swarm connect ... to connect my node to a remote bootstrap node. Then I can access the uploaded file remotely like this http://remoteip:port/ipfs/hash ...
But then after a while that is no longer the case, and I need to re-execute ipfs connect ... on my local node so that the file is again accessible. Is it normal? Is there way to keep the nodes connected? I would think that ipfs bootstrap add .. would resolve this, but it doesn’t.
#2 Deleting a hash
I understand that to keep a file on a given node I need to pin it, otherwise the garbage collector will remove it the next time it’s executed. Say I pin a given file to several nodes. And then I wish to remove that file from all nodes. Do I need to connect to each node and unpin the file on each node? Can I unpin a file from a remote node?
For now, I’m working with very small files, but in the future, I will need to work with large files and I wasn’t able to find a command or something that could tell me “replication progress” or something similar to get to know whether a file is being transferred to a node when is requested. Anyway, this is a side comment, I’m more interested in any feedback related to the first 2 scenarios.
Thanks in advance!
