In ipfs-cluster, is my understanding correct that by setting allocator to reposize it sorts the selected nodes for the new pin request based on the node with lowest reposize (lowest pinned items) first?
So basically, does nodes with lower repo size are prioritized over those with higher repo size?
Yes, this is correct.
