Backups Questions
What would be the best way to backup pins on a cluster? In the event of let’s say a trusted node getting hacked, a bad actor could remove and delete all pins which would propagate across the cluster.
That would be a problem.
Is backing up just .ipfs enough to restore the pins on the cluster? Or is also a list of CID required?
For the ipfs-cluster part (the cluster pins and their options/metadata), see Data, backups and recovery - Pinset orchestration for IPFS
For the ipfs part (the actual pins), usually backing up .ipfs does it, or even .ipfs/blocks.
