Block Chain or Not?
I’m planning to drop the top level hash of a directory of documents into a block chain. Is that overkill? Is there an indelible time stamp from ipfs at time of document addition that I can use instead of the block chain?
Couldn’t you just put a metadata file in the directory with the timestamp?
Thank you. Anyone else?
