From @ajthemacboy on Mon Mar 13 2017 00:25:01 GMT+0000 (UTC)
Can I make IPFS connect to more peers, either by:
- Increasing the peer limit or scan interval with some environmental variable or config option?
- Running a command to search for more?
- Connecting/downloading numerous files?
- Any other way?
Copied from original issue: Can I instruct IPFS to connect to more peers? 路 Issue #237 路 ipfs-inactive/faq 路 GitHub
