When using the HTTP API for IPNS publishing, you have the option to set a ttl and lifetime value. Yesterday I was poking around the internals of the IPNS system within go-ipfs and noticed that there is only one concept of “time duration” and that is a TTL.
There are functions that can be used to publish records within the namesys system. Here is the interface
// Publisher is an object capable of publishing particular names.
type Publisher interface {
// Publish establishes a name-value mapping.
// TODO make this not PrivKey specific.
Publish(ctx context.Context, name ci.PrivKey, value path.Path) error
// TODO: to be replaced by a more generic 'PublishWithValidity' type
// call once the records spec is implemented
PublishWithEOL(ctx context.Context, name ci.PrivKey, value path.Path, eol time.Time) error
When poking around further, the only difference between Publish and PublishWithEOL is that Publish uses a default EOL value, and feeds that into PublishEOL
func (ns *mpns) PublishWithEOL(ctx context.Context, name ci.PrivKey, value path.Path, eol time.Time) error {
id, err := peer.IDFromPrivateKey(name)
if err != nil {
return err
if err := ns.ipnsPublisher.PublishWithEOL(ctx, name, value, eol); err != nil {
return err
ttl := DefaultResolverCacheTTL
if ttEol := eol.Sub(time.Now()); ttEol < ttl {
ttl = ttEol
ns.cacheSet(peer.IDB58Encode(id), value, ttl)
return nil
Publish looks like the following
// Publish implements Publisher
func (ns *mpns) Publish(ctx context.Context, name ci.PrivKey, value path.Path) error {
return ns.PublishWithEOL(ctx, name, value, time.Now().Add(DefaultRecordTTL))
where DefaultRecordTTL is const DefaultRecordTTL = 24 * time.Hour
From what I can gather, there is no lifetime value anywhere, and instead the only time expiration value is TTL.
So my question(s):
- What is the difference between
ttlandlifetime - Why does the namesys system not have 2 time expiration values, like the API which has concepts of
ttlandlifetime
