Close ipfs node js-ipfs
I have a react app that uses js-ipfs to add files to the network.
In the app there’s an ‘upload file’ page that starts a js-ipfs node when the component mounts like this:
startIPFS = async function (){
  •    const node = await window.Ipfs.create()*
  •    console.log('starting ipfs', node)*
  •    this.setState({node: node})*
componentDidMount(){
  •  startIPFS()*
I can then use this.state.node to add files like this:
for await (const file of await this.state.node.add({
  •        path: someFileName,*
  •        content: Buffer.from(fileData, 'base64')*
  •        console.log('Added file:', file.path, file.cid.toString()) *
The problem is if the user navigates away from the upload page and back to it later an error is thrown because the ipfs node has already been created: LockExistsError: Lock already being held for file: ipfs/repo.lock
Is there a way to close the node when a user navigates away from the page (ie when the component unmounts). I’m hoping for something like window.Ipfs.close()
Or is it better practice to start a node on the entire web app loading? so that way I’m not creating and closing the ipfs node every time a user lands on the ‘upload file’ page
I was able to figure it out.
as noted before I started the node like this:
so when the component unmounts I closed it like this:
    this.state.node.stop().catch(err => console.error(err))
