I’m trying to connect from an node app using js-libp2p to a kubo-ipfs. Currently I’m getting this err::
CodeError: message length length too long
at DefaultUpgrader._encryptOutbound (file:///Users/salimbene/dev/ipfs/node_modules/libp2p/dist/src/upgrader.js:520:19)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
at async DefaultUpgrader.upgradeOutbound (file:///Users/salimbene/dev/ipfs/node_modules/libp2p/dist/src/upgrader.js:199:21)
at async TCP.dial (file:///Users/salimbene/dev/ipfs/node_modules/@libp2p/tcp/dist/src/index.js:79:22)
at async DefaultTransportManager.dial (file:///Users/salimbene/dev/ipfs/node_modules/libp2p/dist/src/transport-manager.js:81:20)
at async queue.add.peerId.peerId [as fn] (file:///Users/salimbene/dev/ipfs/node_modules/libp2p/dist/src/connection-manager/dial-queue.js:154:38)
at async raceSignal (file:///Users/salimbene/dev/ipfs/node_modules/race-signal/dist/src/index.js:28:16)
at async Job.run (file:///Users/salimbene/dev/ipfs/node_modules/@libp2p/utils/dist/src/queue/job.js:56:28) {
code: 'ERR_ENCRYPTION_FAILED',
props: {}
This is the configuration in kubo-ipfs node:
"API": {
"HTTPHeaders": {
"PUT",
"POST"
"http://localhost:3000",
"http://127.0.0.1:5001"
"Addresses": {
"Announce": null,
"AppendAnnounce": null,
"NoAnnounce": null,
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001",
"/ip6/::/udp/4001/quic-v1",
"AutoNAT": {},
"Bootstrap": [
"/ip4/10.128.0.2/tcp/4001/p2p/QmVKuLVFyBX2ZSyB2w7YLpH4AM7YCdaqdNRjwZa9cR335M"
"DNS": {
"Resolvers": null
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": "1h",
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"path": "blocks",
"sync": true,
"type": "flatfs"
"mountpoint": "/blocks",
"prefix": "flatfs.datastore",
"type": "measure"
"child": {
"compression": "none",
"path": "datastore",
"type": "levelds"
"mountpoint": "/",
"type": "measure"
"type": "mount"
"StorageGCWatermark": 90,
"StorageMax": "10GB"
"Discovery": {
"MDNS": {
"Enabled": true,
"Interval": 10
"Experimental": {
"FilestoreEnabled": false,
"OptimisticProvide": false,
"P2pHttpProxy": false,
"QUIC": false,
"ShardingEnabled": false,
"StrategicProviding": false,
"UrlstoreEnabled": false
"Gateway": {
"APICommands": [],
"DeserializedResponses": null,
"DisableHTMLErrors": null,
"ExposeRoutingAPI": null,
"HTTPHeaders": {
"X-Requested-With",
"Range"
"NoDNSLink": false,
"NoFetch": false,
"PathPrefixes": [],
"PublicGateways": null,
"RootRedirect": "",
"Writable": false
"Identity": {
"PeerID": "12D3KooWGnC5m82ccmXayxe5qYtH1PupxuXtZpWEe2swTPfbn4Bk"
"Internal": {},
"Ipns": {
"RecordLifetime": "",
"RepublishPeriod": "",
"ResolveCacheSize": 128
"Migration": {
"DownloadSources": null,
"Keep": ""
"Mounts": {
"FuseAllowOther": false,
"IPFS": "/ipfs",
"IPNS": "/ipns"
"Peering": {
"Peers": null
"Pinning": {},
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": ""
"Pubsub": {
"DisableSigning": false,
"Router": "",
"StrictSignatureVerification": false
"Reprovider": {},
"Routing": {
"Methods": null,
"Routers": null
"Swarm": {
"AddrFilters": null,
"ConnMgr": {},
"DisableNatPortMap": false,
"DisableRelay": false,
"EnableRelayHop": false,
"RelayClient": {},
"RelayService": {},
"ResourceMgr": {},
"Transports": {
"Multiplexers": {},
"Network": {},
"Security": {}
In js-libp2p I’m using noise() as encryption method. Should I be able to connect from js-libp2p to kubo-ipfs? I’ve tried other encryption methods, but fails as well. With plaintext() I also get Encryption error but with core error “missing newline”. More details here: ERR_ENCRYPTION_FAILED with libp2p connecting to kubo-ipfs - Stack Overflow
Any tips is greatly appreciated. Been stuck here for a while.
