I want to connect my nodejs application with a 4 node private IPFS network.
When i am using npm ipfs module, by default it is connecting to ipfs global repository.
What configurations and code addition i need to make to connect my application with my private IPFS network.
Should i use any other ipfs module??
i already have a separate 4 node Private IPFS Network.
I just want to store data from my node application to this ipfs network and i dont want to create a new node.
I thought that maybe i can connect my network using any of the peer address. Is it possible? If Yes, then how?
Using ipfs-http-client i am able to connect to my local peer but when i am adding data into ipfs, instead of returning the proper output with filepath and CID, i am getting this Output: Object [AsyncGenerator] {}
@hector I resolved this issue and i am able to connect it to my local ipfs repoitory.
See, now i have to connect my nodejs application to the IPFS Private Network. I am not able to understand how to do it.
I have 4 ipfs peers, each will have different id.
The API address is same for all the 4 peers i.e. ââ/ip4/0.0.0.0/tcp/5001ââ
The Gateway is also same for for all these 4 peers i.e. ââ/ip4/0.0.0.0/tcp/4001â
And when i am trying to connect it, i am getting connection refused error.
I think i am missing something and i am not doing it properly.
Below is my connection logic: const ipfsClient = require(âipfs-http-clientâ); const ipfs = ipfsClient(â/ip4/0.0.0.0/tcp/5001â);
Using this i am able to connect it locally but i am deploying the complete project inside kubernetes cluster, there it is showing connection refused error.
This IPFS Network is running inside a kubernetes clusterâŚand my nodejs application is also running in this clusterâŚ
So at the configuration level i pointed my IPFS client to the API service endpoint defined by me in the yaml file.
IPFS we are using just for secure file storageâŚMy client wants to explore MinIO as an alternative to IPFS. So how will IPFS compare with MinIO?
