Create multiple IPFS PeerIDs on the same node
I was trying to create multiple peerIDs on the same node to try out various commands, and because I didnt necessarily trust random peers on the internet.
I only have access to one linux box running on a virtual box.
Following the process here: https://github.com/ipfs/faq/issues/162
I created two .ipfs folders, changed the ports. However the peerID for both folders is the same.
If I have two daemons running with the same peerID, will I be able to push and fetch files from the same peerID?
No. Just generate a different peer ID for your second daemon.
You can use https://github.com/whyrusleeping/ipfs-key (or just ipfs init setting the right IPFS_PATH (if my memory is correct))
Thanks… This worked great!
