Fastest way to pull a directory from IPFS
I am currently working on a project that requires me to download a directory from IPFS. The directories are usually filled with around 10.000 files. Each file is usually not even 1kb in size. The speeds for pinning and then getting a directory are decent (usually around a minute), but I was wondering if there are ways to speed this up. I am aiming to find a way to get everything in under 30 sec. I know IPFS works on a peer-to-peer basis and I thus rely on the speed of other nodes which I can’t control. But are there certain ways to improve the speed at which I can grab data from the directories? I also tried to use the IPFS HTTP gateway distributed over a few servers without any success. Any tips on increasing the pin/get speed are highly appreciated.
Pinning is the fastest path to grab things as using the same bitswap session for the whole thing optimizes fetching, and dag traversal happens in parallel when possible I think.
If anything, try tuning the configuration (disable sync, and check the bitswap internals options).
