Is there anything I am missing it shows me fuse test failed for fuse/ipns and fuse/readonly on the master branch
Version : 0.11.0-dev
go-version: go1.16.5 linux/amd64
error:
FAIL github.com/ipfs/go-ipfs/fuse/ipns 600.065s
? github.com/ipfs/go-ipfs/fuse/mount [no test files]
ok github.com/ipfs/go-ipfs/fuse/node 0.559s
2021-08-24T16:53:06.349+0530 ERROR fuse/ipfs readonly/readonly_unix.go:100 could not convert protobuf or raw node
--- FAIL: TestIpfsBasicRead (10.16s)
ipfs_test.go:95: open /tmp/fusetest466278213/QmNroDRxQQwSArQLCsPeCdy8HW4ykLAk9x2ATyWZiU28XJ: no such file or directory
2021-08-24T16:53:16.622+0530 ERROR fuse/ipfs readonly/readonly_unix.go:100 could not convert protobuf or raw node
2021-08-24T16:53:16.623+0530 ERROR fuse/ipfs readonly/readonly_unix.go:100 could not convert protobuf or raw node
--- FAIL: TestIpfsStressRead (10.27s)
ipfs_test.go:227: open /tmp/fusetest475273696/Qma4Z8hmw5GTPB5JgVNUeojdZxSJoJNmtkPFs9wpyWbh9S/child2/child3: no such file or directory
2021-08-24T16:53:27.080+0530 ERROR fuse/ipfs readonly/readonly_unix.go:100 could not convert protobuf or raw node
--- FAIL: TestIpfsBasicDirRead (10.57s)
ipfs_test.go:264: open /tmp/fusetest591119807/Qmb4KMuCZunN4qsYbKXt86vTymcJF4PK8efstsPEV3847n/actual: no such file or directory
2021-08-24T16:53:37.834+0530 ERROR fuse/ipfs readonly/readonly_unix.go:100 could not convert protobuf or raw node
--- FAIL: TestFileSizeReporting (10.65s)
ipfs_test.go:298: stat /tmp/fusetest652810258/QmcwbeJBHdyta5Y7fRB2vkYZTFtbBsoAxBHYMgsUzibFnX: no such file or directory
FAIL
FAIL github.com/ipfs/go-ipfs/fuse/readonly 41.704s
