Im running a two node IPFS cluster. I have quite limited disk space on one of the machines. I do need to pin some files, but the data I need to pin is very small, only a few MB. The problem I have is that the folder .ipfs-cluster/badger is growing until it fills the available disk space on one of the cluster nodes. The folder contains over 20GB of data when it maxes out the disk. Incidentally this is much larger than the whole of the data in .ipfs.
Is there a way to control the maximum size of this badger database, ideally limiting it to 10GB or less? How? What would be the consequences of doing so?
So, using 0.14.0-rc2 and using a fresh init with default parameters (just copying peerstore and identity from previous installation):
There is still a badger database using a lot of disk space, not as much but still a lot.
There seems to be a memory leak, over a few days the ipfs-cluster-service process gradually ate up all the RAM.
I see this error message frequently in the log: ipfs ipfs-cluster-service[23277]: 2021-07-12T10:04:33.414Z ERROR monitor pubsubmon/pubsubmon.go:136 msgpack decode error [pos 1]: only encoded map or array can decode into struct
What do you call a lot? The GC cycle by default happens every 15 minutes and for me it correctly sized down badger folders to a very acceptable size (from 100GB to 1GB), now if you are super limited on space it may be that GC does not help you much and that the only way to make it work would be to play with badger configuration settings around table sizes etc. you may be better off with leveldb then.
I am not sure about memory leak. I do not see that on my own peers. If you can run with ipfs-cluster-service --stats daemon and get a heap profile for me with curl localhost:8888/debug/pprof/heap > heap that would be good. Other than that, how are you using your nodes? Are they idling while this is happening?
The error message is because not all your peers are on 0.14.0, you need to upgrade all peers.
