I have a new server with ipfs-go installed
I have ran ipfs init
and started the ipfs daemon
now when i try the instructions from the documentation it just sits there with a blinking cursor i am unsure why it does not work I followed the instructions.
edit:
To clarify.
Install ipfs-go
ipfs init (worked)
ipfs daemon (started)
ipfs id
sits there and does nothing and never returns to command prompt
if i shut down the daemon this is what happens
ipfs id
Error: cannot connect to the api. Is the deamon running? To run as a standalone CLI command remove the api file in $IPFS_PATH/api
