How can I prevent phishing with ipfs?
I think ipfs is vulnerable to phishing because of the low address readability.
Well, it depends if you mean as a content provider or as a consumer.
As a provider, don’t run a public gateway. Or, if you do, make sure it only serves your content, and nothing else.
As a consumer, IPFS really doesn’t make any difference, as phishing is a web problem, regardless of how it’s served. The only real answer is constant vigilance; don’t enter your information unless you have verified where you are entering it (and yes, there are ways even around that, but that’s a deeper problem that has to do with how the internet works, and has no simple solution).
