Hi all, I have a question about the filestore: if two files have the same chunk, then there will only be an index block to A file in the filestore, After the A file is deleted and do GC, the index will still be there but it won鈥檛 update the index to the B file
While using FileStore, I encountered an issue: File A and File B have a completely identical block (for example, the first 256 KiB of both files are the same). However, in the implementation of FileStore, this block is only linked to either File A or File B. If this block is linked to File A, then after I delete File A and call a garbage collection (GC), the block still exists. However, the block remains linked to File A, and it does not automatically update to link to File B just because File A is deleted and File B still exists.
