hi, i have a private ipfs network , it has 4 node in private network. Now i want to connect 1 node in private ipfs to global ipfs. Can you help me ?
hi,
one check you have a proxy. in case of you have a proxy you need to check external comunication on 4001 / 5001 et other prot use by ipds node.
second read that https://docs.ipfs.io/guides/examples/bootstrap/
Regards
it worked, thank you
