I understand the node is created with its dependencies supplied through injection. However, the core.NewNode function provides very limited capacity for customization. I tried to build the core.IpfsNode by hand, but discovered its ctx is unexpected.
So I want to know what is the idiomatic way to create a customized core.IpfsNode instance, for example, with my own BlockStore injected? Thanks!
