It seems that js-ipfs-http-client doesn’t expose libp2p, so pubsub-room cannot be used.
Pubsub looks not working here. Any example ?
you need to be sure your IPFS daemon enable experimental feature to use pub-sub i think https://github.com/ipfs/go-ipfs/blob/master/docs/experimental-features.md
I have already enabled it, of course
I checked
PS D:\go-ipfs> ipfs pubsub peers
QmXWMXquytgYKrMM3AZ8WCfxYqJdg2e2YK5aqocCT2r8Au
There’s only one peer.Is there anything wrong
Could you test it with me ? I run ipfs pubsub sub abc. I don’t know if it will work when you pub something
I am trying to implement ZeroNet here, but it has to broadcast the new content of a site or get the information from another peer while connecting to it.
Is pubsub really working ?
I suddenly found that I can also use IPNS to do that.
ipns cannot resolve …
