#### Version information:
ipfs version --all
go-ipfs version: 0.4.23-6ce9âŚa35
Repo version: 7
System version: amd64/darwin
Golang version: go1.13.8
config file. Enabled AutoNAT. Also enabled quic.
"Identity": {
"PeerID": "QmatWUFpQZo1ZUb7tvhQom8tA8QutiPby9uaeuWf7qbRcx",
"PrivKey": "XXX"
"Datastore": {
"StorageMax": "10GB",
"StorageGCWatermark": 90,
"GCPeriod": "1h",
"Spec": {
"mounts": [
"child": {
"path": "blocks",
"sync": true,
"type": "flatfs"
"mountpoint": "/blocks",
"prefix": "flatfs.datastore",
"type": "measure"
"child": {
"compression": "none",
"path": "datastore",
"type": "levelds"
"mountpoint": "/",
"type": "measure"
"type": "mount"
"HashOnRead": false,
"BloomFilterSize": 0
"Addresses": {
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001"
"Announce": [],
"NoAnnounce": [],
"Gateway": "/ip4/127.0.0.1/tcp/8080"
"Mounts": {
"IPFS": "/ipfs",
"IPNS": "/ipns",
"FuseAllowOther": false
"Discovery": {
"MDNS": {
"Enabled": true,
"Interval": 10
"Routing": {
"Type": "dht"
"Ipns": {
"RepublishPeriod": "",
"RecordLifetime": "",
"ResolveCacheSize": 128
"Bootstrap": [
"/dnsaddr/bootstrap.libp2p.io/ipfs/QmNnooDu7bfjPFoTZYxMNLWUQJyrVwtbZg5gBMjTezGAJN",
"/dnsaddr/bootstrap.libp2p.io/ipfs/QmQCU2EcMqAqQPR2i9bChDtGNJchTbq5TbXJJ16u19uLTa",
"/dnsaddr/bootstrap.libp2p.io/ipfs/QmbLHAnMoJPWSCR5Zhtx6BHJX9KiKNN6tpvbUcqanj75Nb",
"/dnsaddr/bootstrap.libp2p.io/ipfs/QmcZf59bWwK5XFi76CZX8cbJ4BhTzzA3gU1ZjYZcYW3dwt",
"/ip4/104.131.131.82/tcp/4001/ipfs/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ",
"/ip4/104.236.179.241/tcp/4001/ipfs/QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM",
"/ip4/128.199.219.111/tcp/4001/ipfs/QmSoLSafTMBsPKadTEgaXctDQVcqN88CNLHXMkTNwMKPnu",
"/ip4/104.236.76.40/tcp/4001/ipfs/QmSoLV4Bbm51jM9C4gDYZQ9Cy3U6aXMJDAbzgu2fzaDs64",
"/ip4/178.62.158.247/tcp/4001/ipfs/QmSoLer265NRgSp2LA3dPaeykiS1J6DifTC88f5uVQKNAd",
"/ip6/2604:a880:1:20::203:d001/tcp/4001/ipfs/QmSoLPppuBtQSGwKDZT2M73ULpjvfd3aZ6ha4oFGL1KrGM",
"/ip6/2400:6180:0:d0::151:6001/tcp/4001/ipfs/QmSoLSafTMBsPKadTEgaXctDQVcqN88CNLHXMkTNwMKPnu",
"/ip6/2604:a880:800:10::4a:5001/tcp/4001/ipfs/QmSoLV4Bbm51jM9C4gDYZQ9Cy3U6aXMJDAbzgu2fzaDs64",
"/ip6/2a03:b0c0:0:1010::23:1001/tcp/4001/ipfs/QmSoLer265NRgSp2LA3dPaeykiS1J6DifTC88f5uVQKNAd"
"Gateway": {
"HTTPHeaders": {
"X-Requested-With",
"Range",
"User-Agent"
"GET"
"RootRedirect": "",
"Writable": false,
"PathPrefixes": [],
"APICommands": [],
"NoFetch": false
"API": {
"HTTPHeaders": {}
"Swarm": {
"AddrFilters": null,
"DisableNatPortMap": false,
"DisableRelay": false,
"EnableRelayHop": false,
"EnableAutoRelay": false,
"EnableAutoNATService": true,
"ConnMgr": {
"Type": "basic",
"LowWater": 600,
"HighWater": 900,
"GracePeriod": "20s"
"Pubsub": {
"Router": "",
"DisableSigning": false,
"StrictSignatureVerification": false
"Reprovider": {
"Interval": "12h",
"Strategy": "all"
"Experimental": {
"FilestoreEnabled": false,
"UrlstoreEnabled": false,
"ShardingEnabled": false,
"P2pHttpProxy": false,
"QUIC": true,
"PreferTLS": false
#### Description:
According to bug 6251, AutoNAT should work when using a swarm key. However, I don't see this happening.
LIBP2P_FORCE_PNET=1 ipfs daemon
Initializing daemon...
go-ipfs version: 0.4.23-6ce9a35
Repo version: 7
Swarm is limited to private network of peers with the swarm key
Swarm key fingerprint: d4574a64137198e7c6c8366f77e37e46
Swarm listening on /ip4/192.168.0.98/tcp/4001
Swarm listening on /ip6/fd01::18eb:9ca2:8968:d339/tcp/4001
Swarm listening on /ip6/fd01::39c2:943c:4774:db16/tcp/4001
Swarm announcing /ip4/192.168.0.98/tcp/4001
Swarm announcing /ip6/fd01::18eb:9ca2:8968:d339/tcp/4001
Swarm announcing /ip6/fd01::39c2:943c:4774:db16/tcp/4001
WebUI: http://127.0.0.1:5001/webui
Gateway (readonly) server listening on /ip4/127.0.0.1/tcp/8080
Daemon is ready
Whereas when I don't use swarm key, I see the NAT traversal happening.
ipfs daemon
Repo version: 7
Swarm announcing /ip4/106.51.29.204/tcp/21683 => The public IP announced
Daemon is ready
Please try to include:
* What you were doing when you experienced the bug.
* Any error messages you saw, *where* you saw them, and what you believe may have caused them (if you have any ideas).
* When possible, steps to reliably produce the bug.
I was using an older version to get this feature working for p2p file sharing. I tried updating to the latest public release and still doesn't work. Let me know if you need any other information.
