From @lockedshadow on Tue Dec 13 2016 15:22:15 GMT+0000 (UTC)
Hello! And first of all, I apologize for my bad english. Hope that you can understand it.
I’m trying to add into mfs some files (previously added via ipfs add) but ipfs files write command produces different hashes than ipfs add.
For example:
$ echo "IPFS Files API is awesome!" > ipfs-files-api-test.txt
$ ipfs add ipfs-files-api-test.txt
added QmUZtQRZG58yB55k5NFPFeYBQ3FMTKydpuNAb66JnxDgup ipfs-files-api-test.txt
Next, let’s try to write this file to mfs:
$ ipfs files write --create /ipfs-files-test ipfs-files-api-test.txt
$ ipfs files stat /ipfs-files-test
QmYJnHQ8yMSursnCvJa2nKEaQKXXFbbLm5MLXqbuHKZdfe
CumulativeSize: 137
ChildBlocks: 2
Type: file
As we can see, hashes is actually different. Seems like one string now known as two different objects. If is actually true, it turns out that deduplication is not performed for this case.
But object, that returned by ipfs files stat command have two child blocks. Maybe one of these blocks is the same object, that was produced by previously executed ipfs add command?
$ ipfs object links QmYJnHQ8yMSursnCvJa2nKEaQKXXFbbLm5MLXqbuHKZdfe
QmejyB5JSYNMcJeQbXuPj4W1DM23DxsWrU42JQFqy3Z7Xe 8
QmPt4vGy69ENW5GJgVN8wSV5UAoG2SapjRYVUDQJVWbACR 35
No, none of these is not QmUZtQRZG58yB55k5NFPFeYBQ3FMTKydpuNAb66JnxDgup, which produced by previously executed ipfs add. But one of those definitely should contains the source string:
$ ipfs get QmUZtQRZG58yB55k5NFPFeYBQ3FMTKydpuNAb66JnxDgup -o result-of-add.txt
$ ipfs get QmPt4vGy69ENW5GJgVN8wSV5UAoG2SapjRYVUDQJVWbACR -o result-of-files-write.txt
$ diff result-of-add.txt result-of-files-write.txt --report-identical-files
Files result-of-add.txt and result-of-files-write.txt are identical
Indeed, it’s the same string. But why the hashes are different? Not exactly what I would like to get.
But OK, we can directly add some previously added hashes to mfs. For example:
$ ipfs files cp /ipfs/QmUZtQRZG58yB55k5NFPFeYBQ3FMTKydpuNAb66JnxDgup /ipfs-files-test-2
$ ipfs files stat /ipfs-files-test-2
QmUZtQRZG58yB55k5NFPFeYBQ3FMTKydpuNAb66JnxDgup #Finally, the same hash!
CumulativeSize: 35
ChildBlocks: 0
Type: file
(BTW, it’s slightly unclear, that we can write to mfs any existing hashes using ipfs files cp. I figured it out only after reading this: https://github.com/ipfs/go-ipfs/issues/2610#issuecomment-241066009)
But what if I now want to overwrite some files, existing into mfs?
$ echo "IPFS Files API is really awesome!" | ipfs add
added QmS2YcaWxiprdGuXgvsNpqnKeRPeKbrDjTZcdw2qdv8yYa QmS2YcaWxiprdGuXgvsNpqnKeRPeKbrDjTZcdw2qdv8yYa
$ ipfs files cp /ipfs/QmS2YcaWxiprdGuXgvsNpqnKeRPeKbrDjTZcdw2qdv8yYa /ipfs-files-test-2
Error: directory already has entry by that name
Actually, I cannot do that. In case that I definitely want to overwrite some files, I’ll have to execute ipfs files rm first, and cannot overwrite it directly, as ipfs files write do. But I don’t want to use ipfs files write, because for now it’s produces different hashes that ipfs add, and don’t allow to perform deduplication.
Tl;dr:
ipfs addandipfs files writeprobably should produce the same hashes, but it’s doesn’t. -
It should to be a bit more clearly explained in documentation, that
ipfs files cpallows to copy existing hashes into mfs, not only files already written to mfs. -
ipfs files cpprobably should have option to overwrite existing files, but it hasn’t.
Copied from original issue: https://github.com/ipfs/support/issues/45
