I am using IPFS version:
root@raspberrypi:~# ipfs --version
ipfs version 0.20.0-rc2
I am using it on a raspberry PI.
It is on a local network, and the router has UPNP enabled.
My default address clauses in the config are:
"Addresses": {
"Announce": [],
"AppendAnnounce": [],
"NoAnnounce": [],
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001",
"/ip4/0.0.0.0/udp/4001/quic",
"/ip6/::/udp/4001/quic",
"/ip6/::/udp/4001/quic-v1",
The above setting works. I can store data into my node and retrieve it via CID.
“ipns” doesn’t appear to work.
I looked at the docs and saw:
“# Configure NAT and port forwarding” in Configure NAT and port forwarding | IPFS Docs → i.e. the guide for configuring NAT.
I port forwarded 4001 from my Public IP to my machine on 192.168.2.11.
Let my public IP address by XXX - it’s an ipv4 address.
I reconfigured the ipfs-daemon with:
"Addresses": {
"Announce": [],
"NoAnnounce": [
"/ip4/XXX/tcp/4001",
"/ip4/XXX/udp/4001/quic",
"/ip4/XXX/udp/4001/quic-v1",
"/ip4/XXX/udp/4001/quic-v1/webtransport"
"Swarm": [
"/ip6/::/tcp/4001",
But suddenly it stopped listening on 192.168.2.11:8080 and port 5001 and port 4001 on ANY address or device.
i.e. It seems to have stopped listening completely.
May 19 11:32:40 raspberrypi systemd[1]: Started IPFS daemon.
May 19 11:32:40 raspberrypi ipfs[31530]: Initializing daemon...
May 19 11:32:40 raspberrypi ipfs[31530]: Kubo version: 0.20.0-rc2
May 19 11:32:40 raspberrypi ipfs[31530]: Repo version: 13
May 19 11:32:40 raspberrypi ipfs[31530]: System version: arm/linux
May 19 11:32:40 raspberrypi ipfs[31530]: Golang version: go1.19.8
May 19 11:32:40 raspberrypi ipfs[31530]: Computed default go-libp2p Resource Manager limits based on:
May 19 11:32:40 raspberrypi ipfs[31530]: - 'Swarm.ResourceMgr.MaxMemory': "4.1 GB"
May 19 11:32:40 raspberrypi ipfs[31530]: - 'Swarm.ResourceMgr.MaxFileDescriptors': 262144
May 19 11:32:40 raspberrypi ipfs[31530]: Theses can be inspected with 'ipfs swarm resources'.
It is running.
SOMETHING is connected to my node on port 4001 but I don’t know what.
So I’m a little confused:
- Why does adding the announce addresses stop the gateway (on port 8080)?
- Why does adding the announce addresses stop the management console thing (on port 5001)?
- What would a
192.168.2.11:54680 145.40.65.77:4001 ESTABLISHED 31530/ipfsbe as reported bytcpdump -anp?
My goal is/was to figure out how to host a web-site on IPFS (because I can, as a hobby)…
I am not sure whether my question is at all clear because I don’t know what to ask, or the right words to ask it.
There is no firewall running but there is a NATted network (and the PI running ipfs is not on a public address).
DSL
