When i try to upload to ipfs, everything is successful, but whenever i try to use blake2b for the hashAlg,it fails with error, no hasher found for blake2b-208. I observed that just sha256 and sha512 are available.
IPFS Version : 0.63.5
Below is the full error
[nodemon] restarting due to changes…
[nodemon] starting node dozie2.js
Swarm listening on /ip4/127.0.0.1/tcp/4002/p2p/12D3KooWRnb6NYEcUaeciXQhCaERJnqcnbPGuQ9BZhQgjqqM64Lx
Swarm listening on /ip4/192.168.8.96/tcp/4002/p2p/12D3KooWRnb6NYEcUaeciXQhCaERJnqcnbPGuQ9BZhQgjqqM64Lx
Swarm listening on /ip4/127.0.0.1/tcp/4003/ws/p2p/12D3KooWRnb6NYEcUaeciXQhCaERJnqcnbPGuQ9BZhQgjqqM64Lx
file:///Users/macbook/Documents/node_apps/RC3-NFT/node_modules/ipfs-core-utils/src/multihashes.js:10
const LOAD_HASHER = (codeOrName) => Promise.reject(new Error(No hasher found for "${codeOrName}"))
Error: No hasher found for “blake2b-208”
at Multihashes.LOAD_HASHER [as _loadHasher] (file:///Users/macbook/Documents/node_apps/RC3-NFT/node_modules/ipfs-core-utils/src/multihashes.js:10:52)
at Multihashes.getHasher (file:///Users/macbook/Documents/node_apps/RC3-NFT/node_modules/ipfs-core-utils/src/multihashes.js:70:31)
at addAll (file:///Users/macbook/Documents/node_apps/RC3-NFT/node_modules/ipfs-core/src/components/add-all/index.js:97:30)
at addAll.next ()
at file:///Users/macbook/Documents/node_apps/RC3-NFT/node_modules/ipfs-core-utils/src/with-timeout-option.js:64:60
at AsyncGenerator.next ()
at last (/Users/macbook/Documents/node_apps/RC3-NFT/node_modules/it-last/index.js:13:20)
at IPFS.add (file:///Users/macbook/Documents/node_apps/RC3-NFT/node_modules/ipfs-core/src/components/add.js:14:26)
at /Users/macbook/Documents/node_apps/RC3-NFT/dozie2.js:64:23```
