I’m able to connect to ipfs http client in react native. How to add an image using ipfs http client? I tried ipfs.add(imageData), didn’t work.
Sorry you’re having problems - could you post a full snippet of the code you are using? Any error message that appears would also be helpful.
Have you read over the IPFS 101 example?
import ipfsClient from 'ipfs-http-client';
const ipfs = ipfsClient({host: 'localhost:5001', port: '5001'});
const upload = async (base64) => {
const results = await ipfs.add(base64);
for await (const item of results) {
console.log(item);
upload(base64);
I got nothing, no error.
Maybe try with host being ‘localhost’ instead of ‘localhost:5001’?
You can use the multiaddr too:
const ipfs = ipfsClient('/ip4/127.0.0.1/tcp/5001')
I’m able to connect. I’m not sure if I upload an image correctly. Do you know how?
Apart from the host thing, your code looks correct.
I think you have to do some additional work to get ipfs-http-client running under react native though: https://github.com/ipfs/js-ipfs/issues/2840#issuecomment-573035578
There’s also a tracking issue to have it running properly under react native: https://github.com/ipfs/js-ipfs/issues/2813
