IPFS Mobile applications, IOS & Android!
Hi there!
I created mobile application for IOS and Android. Application allow easy upload file from gallery, camera or upload file by URL to IPFS.
IOS: ‎App Store: IPFS Uploader
Android: https://play.google.com/store/apps/details?id=com.sly13.ipfs_uploader
So, I have a question, how I can add this apps to this site https://awesome.ipfs.io ?
Thanks!
Hello
Your application is very good! Simple and elegant :smiling_face_with_three_hearts:
For add a new project, see here: https://github.com/ipfs/awesome-ipfs/blob/master/CONTRIBUTING.md
Hi, I can’t use Termux whenever I start daemon. It the says “[…] Daemon is ready” and the $-Sign for the input disappears. How do I fix that? I already tried uninstalling, restarting, etc. Thank you.
Try installing termux from f-droid.org, the play store one is really outdated.
Thank you, this worked!
