I want to run js-ipfs on the IOS platform, and make the iPhone an ipfs node, Has anyone ever done a job that could give me guidance?
hi,
i think you need to talk with somes developpers are worked on implementation of IPFS see on that : https://github.com/ipfs/ipfs#protocol-implementations and create or found a implementation on cocoa or swift (maybe with swift you can use js implementation : https://developer.apple.com/swift/ https://medium.com/swift-programming/from-swift-to-javascript-and-back-fd1f6a7a9f46).
Regards
did you achieve this?
While not specifically for js-ipfs, the following is relevant:
