IPFS Start ipfs daemon direct from the go application
Hi everyone
I am developing an application in Go that uses IPFS to add files and to send messages through pubsub feature.
I would like to start the daemon directly from the go application. I had tried calling a bash file with the following commands
if [ ! -e ${HOME}/.ipfs/api ]
then
_ ipfs daemon --enable-pubsub-experiment &_
else
_ echo “IPFS already started”_
fi
while [ ! -e ${HOME}/.ipfs/api ]
do
_ echo “Waiting for IPFS to start”;_
_ sleep 1_
done
but it had not working.
Someone know a library that I can use in go to start the daemon directly from the application?
Thanks in advance
Diana
Hi @dserna,
I’m interested in this question as well.
My current approach is to understand go-ipfs/cmd/ipfs which “implements the primary CLI binary for ipfs.”
There should be a way to starting the daemon, i.e., the API server. :grinning:
Tomorrow I will work on it and post my findings.
Cu, Stefan
Hi @dserna,
I did it. Have a look https://github.com/stefanhans/go-ipfs-play/tree/master/daemon
My next approach will be to import "syscall" and use it to check for ipfs daemon
cu, Stefan
Have a look https://github.com/stefanhans/go-ipfs-play/tree/master/ipfs-daemon-start
Hi @stefanhans65
Thanks a lot :hugs:
I had tested the example https://github.com/stefanhans/go-ipfs-play/tree/master/ipfs-daemon-start
and it works perfect, I had modified the line 19 to:
cmd.Args = []string{“ipfs”, “daemon”, “–enable-pubsub-experiment”}
because I am working with the experimental feature pubsub and it works fine…
I had also find one example to start the ipfs daemon using the syscall (for Raspbian Stretch, Ubuntu 15.04 and newer, CentOS 7 and newer):
** Note: you will need to change the line Environment=IPFS_PATH={{ipfs_path}} with you enviroment path
I had used it to start the ipfs daemon by boot in a raspberry and beaglebone and it works fine.
Thanks again for your help
Diana
Hi @dserna,
you are very welcome :grinning:
BTW: What API do you use? I’m playing around with these two currently:
Cheers, Stefan
:wave: Found out you are using ‘go-ipfs-api.’ The ‘unofficial’ in the README title makes me consider the ‘interface-go-ipfs-core.’ :thinking:
Hi @stefanhans65
I had installed go-ipfs, since I am using different machines I had installed the go-ipfs v0.4.19 linux binary arm (for an arm machine with linux), the bare bones IPFS installer for Raspberry from claudiobizzotto and updated it to the version 0.4.19
I have written some applications in Go to work with IPFS and they are using the go-ipfs-api, but I guess after to read the README I will try with the interface-go-ipfs-core :roll_eyes:
about the ipfs-daemon.service.tpl
you should create this file in the folder /lib/systemd/system
to enable you can use the following command: systemctl enable ipfs-daemon
systemctl {disable|status|start|stop} ipfs-daemon
Liebe Grüße
Diana
Hi @dserna,
you’ve probably seen my posting
Let’s see :grinning:
Liebe Grüße aus München
Stefan
