Dentrax
January 26, 2022, 8:42pm
#1
Hello
I was trying to connect Pinata Cloud to ls and get my own CIDs but didn’t make it work. Here is what I’ve done so far:
[WORKS] IPFS Desktop
Open IPFS Desktop
Click “Peers” tab
Add each 6 addresses of Pinata
Jump to “Files” tab
Search CID: /ipfs/QmVYfNCBqrBHmgniv7NSgntafTXrh53NXSGsCziE8JuJWr
Wait a few mins and you will see the files
[DOES NOT WORK] IPFS CLI
$ ipfs init
$ ipfs daemon - another terminal session
$ watch ipfs bitswap stat - another terminal session
$ ipfs swarm connect /dnsaddr/fra1-1.hostnodes.pinata.cloud
$ ipfs swarm connect /dnsaddr/fra1-2.hostnodes.pinata.cloud
$ ipfs swarm connect /dnsaddr/fra1-3.hostnodes.pinata.cloud
$ ipfs swarm connect /dnsaddr/nyc1-1.hostnodes.pinata.cloud
$ ipfs swarm connect /dnsaddr/nyc1-2.hostnodes.pinata.cloud
$ ipfs swarm connect /dnsaddr/nyc1-3.hostnodes.pinata.cloud
$ ipfs ls /ipfs/QmVYfNCBqrBHmgniv7NSgntafTXrh53NXSGsCziE8JuJWr - almost waited ~10+ mins and nothing happened / bitswap stats did not change
What I’m missing here? Any thoughts? Thanks!
Jorropo
January 26, 2022, 8:46pm
#2
Dentrax:
ipfs swarm connect
Doesn’t make the connection stays, if the connection was useless after 20s by default it is closed.
You should use a pinning service that supports automatic content discovery (DHT).
Or follow this guide to “peer” them: Peering with content providers | IPFS Docs
Dentrax
January 26, 2022, 9:50pm
#4
Thanks for clarifying! Just tried following command but bitswap metrics still shows zero and ls does nothing:
$ ipfs swarm peering add /ipfs/QmWaik1eJcGHq1ybTWe7sezRfqKNcDRNkeBaLnGwQJz1Cj /ipfs/QmNfpLrQQZr5Ns9FAJKpyzgnDL2GgC6xBug1yUZozKFgu4 /ipfs/QmPo1ygpngghu5it8u4Mr3ym6SEU2Wp2wA66Z91Y1S1g29 /ipfs/QmRjLSisUCHVpFa5ELVvX3qVPfdxajxWJEHs9kN3EcxAW6 /ipfs/QmPySsdmbczdZYBpbi2oq2WMJ8ErbfxtkG8Mo192UHkfGP /ipfs/QmSarArpxemsPESa6FNkmuu9iSE1QWqPX2R3Aw6f5jq4D5
add QmWaik1eJcGHq1ybTWe7sezRfqKNcDRNkeBaLnGwQJz1Cj success
add QmNfpLrQQZr5Ns9FAJKpyzgnDL2GgC6xBug1yUZozKFgu4 success
add QmPo1ygpngghu5it8u4Mr3ym6SEU2Wp2wA66Z91Y1S1g29 success
add QmRjLSisUCHVpFa5ELVvX3qVPfdxajxWJEHs9kN3EcxAW6 success
add QmPySsdmbczdZYBpbi2oq2WMJ8ErbfxtkG8Mo192UHkfGP success
add QmSarArpxemsPESa6FNkmuu9iSE1QWqPX2R3Aw6f5jq4D5 success
Jorropo
January 27, 2022, 12:50am
#6
Do they even host this file ?
How do you know pinata is pinning this file ?
Dentrax
January 27, 2022, 6:05am
#7
Dentrax
January 27, 2022, 7:55pm
#8
Profile settings:
I can see Pin Status: Pinned info in my files page.
