ipfs version 0.5.1
ipfshttpclient-0.4.13.2
Ipfs is already running on the background using (nohup ipfs daemon &). Afterwards I tried to obtain already connected ipfs’s client.
$ ipfs config Addresses
"Announce": [],
"NoAnnounce": [],
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001"
import ipfshttpclient
client = ipfshttpclient.connect('/ip4/127.0.0.1/tcp/5001/http')
=> What may be the reason of this error? How could I fix it?
Error log:
❯ ./ipfs_daemon.py
[2020-06-04 02:48:12 lib.py:314 - is_process_on()] IPFS is already running on the background
Traceback (most recent call last):
File "/home/alper/venv/lib/python3.7/site-packages/ipfshttpclient/http.py", line 266, in _do_raise_for_status
response.raise_for_status()
File "/home/alper/venv/lib/python3.7/site-packages/requests/models.py", line 941, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 405 Client Error: Method Not Allowed for url: http+ip4://127.0.0.1:5001/api/v0/version?stream-channels=true
The above exception was the direct cause of the following exception:
File "./ipfs_daemon.py", line 30, in <module>
File "/home/alper/venv/lib/python3.7/site-packages/ipfshttpclient/client/__init__.py", line 101, in connect
version_str = client.version()["Version"]
File "/home/alper/venv/lib/python3.7/site-packages/ipfshttpclient/client/base.py", line 15, in wrapper
result = func(*args, **kwargs)
File "/home/alper/venv/lib/python3.7/site-packages/ipfshttpclient/client/miscellaneous.py", line 204, in version
return self._client.request('/version', decoder='json', **kwargs)
File "/home/alper/venv/lib/python3.7/site-packages/ipfshttpclient/http.py", line 51, in wrapper
return func(self, *args, **merged)
File "/home/alper/venv/lib/python3.7/site-packages/ipfshttpclient/http.py", line 386, in request
username, password, data, timeout)
File "/home/alper/venv/lib/python3.7/site-packages/ipfshttpclient/http.py", line 307, in _request
self._do_raise_for_status(res)
File "/home/alper/venv/lib/python3.7/site-packages/ipfshttpclient/http.py", line 286, in _do_raise_for_status
six.raise_from(exceptions.StatusError(error), error)
File "<string>", line 3, in raise_from
ipfshttpclient.exceptions.StatusError: HTTPError: 405 Client Error: Method Not Allowed for url: http+ip4://127.0.0.1:5001/api/v0/version?stream-channels=true
