Hello.
I just found this on my router UI… is this normal?
They should be removed when the daemon shutdown, how are you running Kubo ? It looks like it’s not being shutdown cleanly.
You should have 1 TCP and 1 UDP forward per instance running live.
I have IPFS Desktop 0.31.0 …now upgrading to 32
Can I delete all these entries? Will IPFS remake them?
It’s perfectly normal. One for each connection you have to another libp2p node or relay out there on The Internet. When you stop the daemon they should disappear in about a minute.
You should only have one forward per listen tuple.
All the connections use the same forward.
I missed this sorry, yes you can delete them and restart your daemon.
