We would like to allow users to restore their databases from an IPNS pointer based on IPFS key names that they maintain. However, due to there being only two endpoints for IPNS name/resolve and name/publish, it doesnt appear that one can derive the IPNS name from a key without re-pointing the IPNS name. Is it possible?
I have found that the keys all exist in the keystore fodler inside of IPFS_HOME, but I’m not sure about the format of these files. The comments here suggest that they are in protobuf format, but I’m not sure how to extract the data meaningfully from there.
For example, using --decode-raw gives me this:
root@ip-172-31-11-196:~# protoc --decode_raw $IPFS_HOME/keystore/keypairfile
1: 0
2: "0\202\004\243\002\001\000\002\202\001\001\000\333\246v\\+s\350\321`8Y\224Y\353I\267h\254\257\334\356Q\276W\017ZA\357\327\331\t\304?\327Y\312tP\201\377\235^\014\376\245Q1*[n\004Lh\377\256F\350\235yr\231\233\353\237D~\321\254j\252\273I[\245rv\3046\3441WO\257\252+\273|\216\207\204z<~2K\265\362\224\016\246\334+\373JE\326\371\n\032,n\025\266\335\374\244\202\242\364>\033\275\345l\327\350\353\\\206~*h\237\223\321\337\037P\212\227\204\014W;\205\314pE\256\207\200\t\3275\256\234\'K\177E\253\355c\225\340\251\370\222\371\247\366\353\0140}\312J\254\267+\007\323\366\357\350\244>[\203\031Z\217\311\'\324_o\017\307\262\034\234F4\267\014\343\221NM\221\214\230\034D*-Pa\315%\2513\016H\311\375\004\345\243Q2\277\007\330\217\363\306\272{\357\237\252\204\332\301q\276\000\362\032\212\212\202I\031\002\003\001\000\001\002\202\001\000\002\003\247\3106\231\314\203\307\007\035C0\003\351\\&8\2270F{7l\242\366g\356d#Xd\225UK<\201\016\217\362\241%\320\246\261+jq\001\377\243Ht\032\014&\030R\001`\034\252\202a\246\206\'4\026\222T?Z\370\314p\354a\270{\377Y\372\271k\307?`+;\372\306\375=F\326wP\006F_t\203\314m\221\210\035 \232Q\264\037F/\337\356V\3028\243\226}9\037M\302\202\305Z%\355\007\010\337\316L\276\203%\233\031\216\010P\235\t\307\372\203\362\206\265\327\022W\032\327e\213k?\001\314\324k\022\303\306W\25798\350\240\357\334\311Ft\275\204\342\207^\326k-)]eD\341\007\372\377-J\261\\cJh\246\212\010\025\t\252Q\\\340\221\330\277q\t6\210${\222\225y\260\266\r\204\014P\257\262DR\307\001\216\250$\212\220\362xp\311\022\321\357*\2309\t\232\342\260\001\002\201\201\000\371p|\305\276\276*\253%\244\276\360i\203Y\002\2217$\372g\017WT!C\225\362n\377`\r\t\203(q\353\323K\202\356X\273B\341\037p\t\017\354|+_\317\313k\210\335\000Fr3pqW\001>G\243\231y\373p7\335\201K\362>\333]Od\365\255\360\373\214\245\237\267R\354GA\366\016W\371@*s05`>}\217\361\363PU2]\225\226]=\356n\005\236P\307w\353\342\001\002\201\201\000\341mfm9y\266\343\251>\314\007C\310\324\210\302\230\210\237\353\021|W\330\035w\223~\'SD9r\272\377;)\250\336)[X<XH\021a\024\3108o\261\214\007\240\301\326\222,\260e\001m\370\320\032\354\246u\231\177\337\227\371\214]\242~{o\020h@\220(-\337FF\340\221X\340\001*\t\376\350\343\345\345\224\336\261g>\276\215\252\335H\233\227\210\256\315\302\372(\376\221\265c\260\3537\031\002\201\200O9A\367\320h7\307\031\362\244NYD\305m\202O\300g\343y\304\343\314\230\331\264!:\354\367\327\020\2304\356\220\262\210\010I\230XZ\206\020\240`5]\016\255\244\242\330)\244\377\244`;$8kH\322\316\020\020\373\34475\027\036,\317\350\324\345c\005\016\336\313\016*\022\244\222\246<\2639(\374OF\263\361\207\232E)\247O[\373\235\252\343\024W\022\336\252\010\264\204\2576$3\346K\276\001\002\201\200\023\347\320\"\226\357\253y\240\351=\244\352\224bH\r>\340\331\226->\030\227\251\312tH\260zF\314\367\327\221P\r\026\257?a\244\201\367\235\255\2030\r\232\006*\334]\224\021i\274\020\234&\337 q\327\026y\215\035WG\226[\332\032M\356ZR\325\364\321\357\331\212\342\272\023\177\220\266\344\355*\315&\202\316\327\310\346#\346\".&\2716\323>\244\371\260@\316\206\266\317\326,\334z\362\351\235k\211\002\201\201\000\311\231\273\205\340\260\0360\252\236G\221\305\201!\305\013\013\\\217N\332\004\364>\314\nP\016\375-\240b\\\246=\264C\t\357\362\303xC\327P\353\034\224\023Xn\204\360\300A3\001N\262\3233r\004\346v\300v\"g\315\034\275\001L;4,\224\302\376\372\324\037Z\232\245)2\364\034\177\307\341\0045(\326\360\3311\265\002\231\265Y\014Cb%\202uB\033\313\177-kr\345\026\247\357\237\247+\310\272"
Which appears to be two binary items, but still nothing I can quite extract the IPNS name from… or is it?
