Join two folders?
How would you add a normal folder to an ipfs folder
Can you give an example of what you mean by an ā€œipfs folderā€ and what you mean by a ā€œnormal folderā€?
HASH FOLDER2 + ipfs add -r /FOLDER1
I’m not sure there’s a single command that will do this easily.
But here’s a simple proof of concept script that will do this.
Assuming HASH is the hash of a folder in IPFS, this script will loop through the contents of a local folder named test2 and add the contents to the existing directory hash. The final hash that’s spit out by the script is the hash of the combined directory.
#!/bin/bash
# hash of folder currently in IPFS
HASH="QmW85q9pmby55reZb9YrcLRr5L2gHcvTFGoSmjADCbhq1w"
FOLDER2="./test2"
for item in "$FOLDER2"/*; do
	tempname="$(basename "$item")"
	temphash="$(ipfs add --pin=false -r -Q "$FOLDER2"/"$tempname")"
	HASH=$(ipfs object patch add-link $HASH "$tempname" "$temphash" )
done
echo $HASH
ipfs object patch add-link; this command can combine HASHFOLDER + REGULAR FILE, should be easy to add hashfolder+ folder functionality or even hashfolder+hashfolder
Yeah, that seems like it would be a reasonable enhancement to merge the links from two IPFS directories.
so off to github we go
