Js-ipfs publish IPNS record error
I successfully ran a IPFS node on my nestjs API using js-ipfs (ipfs-core).
When trying to publish a IPNS record, I get the following error:
Error: ipns record for f5uxa3ttf4acicabciqhcqrufyvadw2s7tyk2lp7tiaca737jtwpi6sjeiwzv4xqpsmwehi could not be stored in the routing - Error: Write failed
    at Object.dbWriteFailedError (/Users/tiagoknoch/source/nestjs-tutorial/mycv/node_modules/datastore-core/cjs/src/errors.js:20:16)
    at TieredDatastore.put (/Users/tiagoknoch/source/nestjs-tutorial/mycv/node_modules/datastore-core/cjs/src/tiered.js:34:20)
    at IpnsPublisher._publishEntry (/Users/tiagoknoch/source/nestjs-tutorial/mycv/node_modules/ipfs-core/cjs/src/ipns/publisher.js:85:19)
    at IpnsPublisher._putRecordToRouting (/Users/tiagoknoch/source/nestjs-tutorial/mycv/node_modules/ipfs-core/cjs/src/ipns/publisher.js:67:5)
Code sample:
  async test() {
    const ipfs = await create();
    const file = await ipfs.add({
      path: 'text.txt',
      content: new TextEncoder().encode(
        'Hello World ' + new Date().toISOString(),
    const addr = `/ipfs/${file.cid.toString()}`;
    const res = await this.node.name.publish(addr);
    console.log(`https://gateway.ipfs.io/ipns/${res.name}`);
