Js-ipfs unit tests failing
I’m interested in working with js-ipfs, and I’m trying to run the unit tests. I’m following these docs but I’m having an issue with chromium:
ipfs-core-utils: Test Browser
ipfs-message-port-protocol: - Setting up chromium
ipfs-core-utils: - Setting up chromium
ipfs-core-utils: ✖ Running tests failed.
ipfs-core-utils: Error: Lock file is already being held
ipfs-core-utils:     at /home/tom/git/js-ipfs/node_modules/proper-lockfile/lib/lockfile.js:68:47
ipfs-core-utils:     at callback (/home/tom/git/js-ipfs/node_modules/graceful-fs/polyfills.js:299:20)
ipfs-core-utils:     at FSReqCallback.oncomplete (fs.js:184:5) {
ipfs-core-utils:   code: 'ELOCKED',
ipfs-core-utils:   file: '/home/tom/.cache/ms-playwright'
ipfs-core-utils: }
ipfs-core-utils: Command failed with exit code 1: pw-test **/*.spec.{js,ts} test/browser.{js,ts} --mode main --config /home/tom/git/js-ipfs/node_modules/aegir/src/config/pw-test.js --timeout=5000
ipfs-core-utils: npm ERR! code ELIFECYCLE
ipfs-core-utils: npm ERR! errno 1
ipfs-core-utils: npm ERR! ipfs-core-utils@0.8.0 test: `aegir test`
ipfs-core-utils: npm ERR! Exit status 1
ipfs-core-utils: npm ERR! Failed at the ipfs-core-utils@0.8.0 test script.
ipfs-core-utils: npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
ipfs-core-utils: npm ERR! A complete log of this run can be found in:
ipfs-core-utils: npm ERR!     /home/tom/.npm/_logs/2021-05-20T20_55_54_706Z-debug.log
lerna ERR! npm run test exited 1 in 'ipfs-core-utils'
lerna WARN complete Waiting for 1 child process to exit. CTRL-C to exit immediately.
npm ERR! Test failed.  See above for more details.
Could this be an environment issue? Or any idea what could cause this?
I’m running on Lubuntu 20.10 with Node version 14.16.1.
Thanks.
