Kubo v0.32.0 is out!
Release Notes:
TLDR:
  • This release includes boxo, go-libp2p, Amino DHT client fixes and experimental opt-in AutoTLS feature that automates /tls/../ws listener setup to allow direct retrieval from JS client in web browser. If you self-host your data, consider enabling it and provide feedback.
Install:
If you depend on Routing.AcceleratedDHTClient=true there is a regression where accelerated client does not crawl the network correctly and the regular one is used instead as a fallback, making announcements slower than expected.
Make sure to update from v0.32.0 to the bugfix patch release v0.32.1 :
