Meson Network IPFS Public Gateway
IPFS can be used as storage layer while meson.network works as a global CDN cache layer.
Origin IPFS link
https://ipfs.io/ipfs/QmbWqxBEKC3P8tqsKc98xmWNzrzDtRLMiMPL8wBuTGsMnR
Accelerated link by meson
https://coldcdn.com/api/cdn/4wdhj2/QmbWqxBEKC3P8tqsKc98xmWNzrzDtRLMiMPL8wBuTGsMnR
Hummm:
  "msg":"bind domain not active",
  "status":202
This is test link, invalid in 30 minutes
Any objects in ipfs can currently be cached of course. Just like your ipfs client is caching the object you can use any other services including cdn from cloudflare or next cloud. While you can make objects available through proxied + cdn accelerated api gateways you can also just have a bunch of ipfs-cluster deployed around the world setting pins on certain files without exposing their gateway because ipfs implementation itself does seeding already
