From @chpio on Tue Apr 07 2015 11:01:03 GMT+0000 (UTC)
say im only reachable via IPv6, but many existing nodes are using IPv4. Is there something like a “gateway” that helps me to reach the IPv4 nodes? (IPv4/6 is just an example. It should also work with TOR, i2p, cjdns…)
Copied from original issue: Multi net routing · Issue #7 · ipfs-inactive/faq · GitHub
