Permanent File Storage with IPFS & Binance Smart Chain
Application Links
Main application link:
https://ipfs-bsc-storage.herokuapp.com/ -
Binance Smart Chain backend repo:
https://github.com/Egesabanci/ipfs-bsc-storage -
Main application repo:
https://github.com/Egesabanci/ipfs-bsc-storage-app
About Application
This is a new type of file storage. Your files cannot be destroyed, cannot be changed, cannot be lost, your file will stay here forever. All the files are stored in the IPFS distributed structure and all pieces of information about your files are stored in the Binance Smart Chain.
How to use it?
You just need a crypto wallet or if I have to be more specific, you need an address that is recognizable from Binance Smart Chain. Then, you are good to go, load your files with your address hash and get your files back with the same address hash that you used to load files to the storage app.
Important note!
The application doesn’t save any kind of information for anything.
