Hi IPFS People
I am currently in a struggle with my current IPFS setup, the problem is that the pinned contents seems to be unreachable by public gateways like `https://ipfs.io/ipfs/.
I have hosted my ipfs in azure container instance and opened the required ports. I also configured to be publicly available but failed to do so it seems, below is my config
"API": {
"HTTPHeaders": {
"X-Requested-With",
"Range",
"User-Agent"
"PUT",
"GET",
"POST",
"OPTIONS"
"Addresses": {
"Announce": [
"/ip4/104.43.103.27/tcp/4001",
"/ip4/104.43.103.27/tcp/443/https",
"/ip4/104.43.103.27/tcp/4001/ws"
"AppendAnnounce": [],
"NoAnnounce": [],
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001",
"/ip4/0.0.0.0/udp/4001/webrtc-direct",
"/ip6/::/udp/4001/webrtc-direct",
"/ip6/::/udp/4001/quic-v1",
"AutoNAT": {
"ServiceMode": "enabled"
"Bootstrap": [
"/ip4/104.131.131.82/udp/4001/quic-v1/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ",
"/dnsaddr/bootstrap.libp2p.io/p2p/QmQCU2EcMqAqQPR2i9bChDtGNJchTbq5TbXJJ16u19uLTa"
"DNS": {
"Resolvers": {}
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": "1h",
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"path": "blocks",
"sync": true,
"type": "flatfs"
"mountpoint": "/blocks",
"prefix": "flatfs.datastore",
"type": "measure"
"child": {
"compression": "none",
"path": "datastore",
"type": "levelds"
"mountpoint": "/",
"type": "measure"
"type": "mount"
"StorageGCWatermark": 90,
"StorageMax": "10GB"
"Discovery": {
"MDNS": {
"Enabled": true
"Experimental": {
"FilestoreEnabled": false,
"OptimisticProvide": true,
"P2pHttpProxy": false,
"StrategicProviding": true,
"UrlstoreEnabled": false
"Gateway": {
"DeserializedResponses": null,
"DisableHTMLErrors": null,
"ExposeRoutingAPI": null,
"HTTPHeaders": {},
"NoDNSLink": false,
"NoFetch": false,
"PublicGateways": null,
"RootRedirect": ""
"Identity": {
"PeerID": "12D3KooWNCPbnZeKQgt9mwykfaRuqHsHSBNzE2qRHs6r8X3iGS1Z"
"Import": {
"CidVersion": null,
"HashFunction": null,
"UnixFSChunker": null,
"UnixFSRawLeaves": null
"Internal": {},
"Ipns": {
"RecordLifetime": "",
"RepublishPeriod": "",
"ResolveCacheSize": 128
"Migration": {
"DownloadSources": [],
"Keep": ""
"Mounts": {
"FuseAllowOther": false,
"IPFS": "/ipfs",
"IPNS": "/ipns"
"Peering": {
"Peers": null
"Pinning": {
"RemoteServices": {}
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": "all"
"Pubsub": {
"DisableSigning": false,
"Router": ""
"Reprovider": {
"Interval": "1h",
"Strategy": "all"
"Routing": {
"Methods": null,
"Routers": null,
"Type": "dhtserver"
"Swarm": {
"AddrFilters": null,
"ConnMgr": {
"GracePeriod": "2m",
"HighWater": 300,
"LowWater": 100
"DialTimeoutSeconds": 60,
"DisableNatPortMap": false,
"EnableAutoRelay": true,
"EnableHolePunching": true,
"RelayClient": {
"Enabled": true,
"StaticRelays": [
"/dns4/relay.ipfs.io/tcp/4001/p2p/QmQvM2mpqkjyXWbTHSUidUAWN26GgdMphTh9iGDdjgVXCy",
"/dns4/relay.dev.ipfs.io/tcp/4001/p2p/QmNnooDu7bfjPFoTZYxMNLWUQJyrVwtbZg5gBMjTezGAJN"
"RelayService": {},
"ResourceMgr": {},
"Transports": {
"Multiplexers": {},
"Network": {
"Relay": true
"Security": {}
"Version": {}
I really need your help on this.
