Problem to see my files in ipfs
Hello i am new in ipfs, i have a question, when i add a file and this give me a hash, why i cant see that hash in ipfs.io/ipfs/ ?
they dont show me a error but says: 504 Gateway Time-out
after add my files i need to wait a time or something like that?, in that case,
How long should I wait after upload my files to see in ipfs ?
thanks a lot and sorry for my bad english :sweat_smile:
on your ipfs node you need to check if you are connect with other node. you can check bootstrap and swarm peers.
hello thanks for the answer , i have this in cosole when i run my code
Swarm listening on /ip4/192.168.56.1/tcp/4002/ipfs/QmbgpyTLCYBy84E1HGwei6niQHiLQmRpfN6SQtfJiyNMUd
i waiting a lot of time and nothings happend , i thing i forget something
ok seems your node cannot connect public peers. have you a proxy or firewall ?
yes , i disabled the firewall , but the same loop when i try to see the file in ipfs :frowning_face:
you can check with ipfs pin command https://docs.ipfs.io/guides/concepts/pinning/ or https://docs.ipfs.io/reference/api/cli/#ipfs-refs-local
i solved , the problem is i forget add the entry, now works ! , thanks for help me :slight_smile:
Hi! I’m experiencing the same issue, @kypanz would you please explain what you mean by “add the entry”? Thank you so much!
what exacly do you wanna do ?
Thanks! It is working now. Just had to wait a bit.
