I use libp2p to upload files to ipfsCluster and disable resource manager in cluster and kubo. But i have this exception if RPS > 64. “cannot reserve outbound stream: resource limit exceeded (0)”
How fix this, help pls
That sounds as if you have not disabled the resource manager.
ipfs config Swarm.ResourceMgr
"Enabled": false
In cluster
"resource_manager": {
"enabled": false,
"memory_limit_bytes": 0,
"file_descriptors_limit": 0
It`s my config. Or do I need to install something else.
it might be a bug. Try enabling it with very high limits.
We put this config, but the situation has not changed
"Enabled": true,
"MaxFileDescriptors": 10000000,
"Memory": 268435456000
Cluster
"enabled": true,
"memory_limit_bytes": 268435456000,
"file_descriptors_limit": 10000000
