Im new to IPFS and I would like to use it programatically using Go to transfer files between nodes. Is there a way to do it?
Thanks.
Thanks.
Here’s a tutorial for transferring files between nodes: https://github.com/ipfs/go-ipfs/blob/master/docs/file-transfer.md
You might also check out the http-api if you want to do this from within a webpage or something: https://github.com/ipfs/js-ipfs-http-client
Hi, Molly
Is Go documentation example programamatic? It seems it only works on console.
Im looking for something such as this:
ipfs = new Ipfs()
ipfs.connect()
response = ipfs.add(file)
Thanks;
