Hi!
I have been really enjoying working with IPFS & OrbitDB writing straight browser javascript against https://cdn.jsdelivr.net/ libraries. I am quite comfortable in JS but have not worked in Node.JS or with NPM or Browserify at all. While I am tinkering on something that is exclusively client-side the deeper I get the more I am finding it harder and harder to get around all the Node “Require” references in examples and missing min.js files so I have decided to take a step back and work through Node.JS. I am having trouble at a very early step here that I have spent an inordinate amount of time road blocked on and would really value some guidance on. Here are the steps I am taking:
I setup my environment like this:
mkdir ipsm
cd ipsm
npm init
npm install http-server
npm install browserify
Create a basic html page at /public/index.html
<!DOCTYPE html> <html> <body> <script src="bundle.js"></script> </body> </html>
Create a JS that does nothing more than reference IPFS at /src/index.js .
const IPFS = require(‘ipfs’)
Modify package.json as follows:
"name": "ipsm",
"version": "0.0.1",
"description": "TEST",
"main": "index.js",
"scripts": {
"serve": "http-server -c-1 -p 12345 public",
"bundle": "browserify src/index.js -o public/bundle.js -d",
"start": "npm run bundle && npm run serve"
"author": "Michael Rosola",
"license": "MIT",
"dependencies": {
"browserify": "^17.0.0",
"http-server": "^0.12.3",
"ipfs": "^0.53.0",
Bundle and start the server:
npm start
Opening a browser I receive the following error:
utils.js:7 Uncaught TypeError: TextEncoder is not a constructor
at Object.446.ipfs-utils/src/temp-dir (utils.js:7)
at o (_prelude.js:1)
at _prelude.js:1
at Object.444…/utils (key.js:5)
at _prelude.js:1
at Object.443…/adapter (index.js:3)
at _prelude.js:1
at Object.632.cids (utils.js:6)
Below is utils.js with line 7 noted:
'use strict' const tempdir = require('ipfs-utils/src/temp-dir') const TextEncoder = require('ipfs-utils/src/text-encoder') <--- here const TextDecoder = require('ipfs-utils/src/text-decoder') exports.utf8Encoder = new TextEncoder('utf8') exports.utf8Decoder = new TextDecoder('utf8')
What I am doing seems consistent with tutorials and examples I have seen. If I omit the reference to IFPS and instead console.log(“hello world”) in my index.js all is well. What am I doing wrong?
Appreciate your help,
Michael
