I don’t have that flag in my configuration. My configuration for my ipfs node that try to retrieve the content using CID is
"API": {
"HTTPHeaders": {}
"Addresses": {
"Announce": [],
"AppendAnnounce": [],
"NoAnnounce": [ ],
"Swarm": [
"/ip4/0.0.0.0/tcp/4001",
"/ip6/::/tcp/4001",
"/ip6/::/udp/4001/quic-v1",
"AutoNAT": {},
"Bootstrap": [
"/ip4/172.20.0.5/tcp/9096/p2p/12D3KooWJ4TbaQQvQxv7qq7PiP7pYeGysuiUDWZNFV7DWfPwBxHD",
"/ip4/127.0.0.1/tcp/9096/p2p/12D3KooWJ4TbaQQvQxv7qq7PiP7pYeGysuiUDWZNFV7DWfPwBxHD",
"/ip4/172.20.0.6/tcp/9096/p2p/12D3KooWHwdMs1rgykeoqSgGUCFgUafK9uUEUPCVXPHyiQZZqQpZ",
"/ip4/127.0.0.1/tcp/9096/p2p/12D3KooWHwdMs1rgykeoqSgGUCFgUafK9uUEUPCVXPHyiQZZqQpZ",
"/ip4/172.20.0.7/tcp/9096/p2p/12D3KooWPBBaX8XsKyiQhrCVZ289z3EQY6XEmZTQx8pjLYfvxESh",
"/ip4/127.0.0.1/tcp/9096/p2p/12D3KooWPBBaX8XsKyiQhrCVZ289z3EQY6XEmZTQx8pjLYfvxESh",
"/ip4/104.131.131.82/udp/4001/quic-v1/p2p/QmaCpDMGvV2BGHeYERUEnRQAwe3N8SzbUtfsmvsqQLuvuJ",
"/dnsaddr/bootstrap.libp2p.io/p2p/QmcZf59bWwK5XFi76CZX8cbJ4BhTzzA3gU1ZjYZcYW3dwt"
"DNS": {
"Resolvers": {}
"Datastore": {
"BloomFilterSize": 0,
"GCPeriod": "1h",
"HashOnRead": false,
"Spec": {
"mounts": [
"child": {
"path": "blocks",
"sync": true,
"type": "flatfs"
"mountpoint": "/blocks",
"prefix": "flatfs.datastore",
"type": "measure"
"child": {
"compression": "none",
"path": "datastore",
"type": "levelds"
"mountpoint": "/",
"type": "measure"
"type": "mount"
"StorageGCWatermark": 90,
"StorageMax": "10GB"
"Discovery": {
"MDNS": {
"Enabled": true
"Experimental": {
"FilestoreEnabled": false,
"Libp2pStreamMounting": true,
"OptimisticProvide": false,
"P2pHttpProxy": false,
"StrategicProviding": false,
"UrlstoreEnabled": false
"Gateway": {
"DeserializedResponses": null,
"DisableHTMLErrors": null,
"ExposeRoutingAPI": null,
"HTTPHeaders": {},
"NoDNSLink": false,
"NoFetch": false,
"PublicGateways": null,
"RootRedirect": ""
"Identity": {
"PeerID": "12D3KooWGKbHEiqZc1uxGQgsh3ABqtD6ccvYv1mwAbcWMe3JmxBS",
"PrivKey": "CAESQEpZA+8FIs+ntKpFko5w4nJnOS/SQLhNAynx9W3kXc+6YKLKbmraPW1qYVenFYwnRpyF3HkdIKQY6yhhts4QEYk="
"Internal": {},
"Ipns": {
"RecordLifetime": "",
"RepublishPeriod": "",
"ResolveCacheSize": 128
"Migration": {
"DownloadSources": [],
"Keep": ""
"Mounts": {
"FuseAllowOther": false,
"IPFS": "/ipfs",
"IPNS": "/ipns"
"Peering": {
"Peers": null
"Pinning": {
"RemoteServices": {}
"Plugins": {
"Plugins": null
"Provider": {
"Strategy": ""
"Pubsub": {
"DisableSigning": false,
"Router": ""
"Reprovider": {},
"Routing": {
"Methods": null,
"Routers": null
"Swarm": {
"AddrFilters": null,
"ConnMgr": {},
"DisableNatPortMap": false,
"RelayClient": {},
"RelayService": {},
"ResourceMgr": {},
"Transports": {
"Multiplexers": {},
"Network": {},
"Security": {}
while the docker-compose.yml for the cluster is version: ‘3.4’
# This is an example docker-compose file to quickly test an IPFS Cluster
# with multiple peers on a contained environment.
# It runs 3 cluster peers (cluster0, cluster1...) attached to kubo daemons
# (ipfs0, ipfs1...) using the CRDT consensus component. Cluster peers
# autodiscover themselves using mDNS on the docker internal network.
# To interact with the cluster use "ipfs-cluster-ctl" (the cluster0 API port is
# exposed to the locahost. You can also "docker exec -ti cluster0 sh" and run
# it from the container. "ipfs-cluster-ctl peers ls" should show all 3 peers a few
# seconds after start.
# For persistence, a "compose" folder is created and used to store configurations
# and states. This can be used to edit configurations in subsequent runs. It looks
# as follows:
# compose/
# |-- cluster0
# |-- cluster1
# |-- ipfs0
# |-- ipfs1
# During the first start, default configurations are created for all peers.
services:
## Cluster PEER 0 ################################################################
ipfs0:
container_name: ipfs0
image: ipfs/kubo:release
ports:
- "4001:4001" # ipfs swarm - expose if needed/wanted
- "5001:5001" # ipfs api - expose if needed/wanted
- "8080:8080" # ipfs gateway - expose if needed/wanted
volumes:
- ./compose/ipfs0:/data/ipfs
cluster0:
container_name: cluster0
image: ipfs/ipfs-cluster:latest
depends_on:
- ipfs0
environment:
CLUSTER_PEERNAME: cluster0
CLUSTER_SECRET: ${CLUSTER_SECRET} # From shell variable if set
CLUSTER_IPFSHTTP_NODEMULTIADDRESS: /dns4/ipfs0/tcp/5001
CLUSTER_CRDT_TRUSTEDPEERS: '*' # Trust all peers in Cluster
CLUSTER_RESTAPI_HTTPLISTENMULTIADDRESS: /ip4/0.0.0.0/tcp/9094 # Expose API
CLUSTER_MONITORPINGINTERVAL: 2s # Speed up peer discovery
ports:
# Open API port (allows ipfs-cluster-ctl usage on host)
- "127.0.0.1:9094:9094"
# The cluster swarm port would need to be exposed if this container
# was to connect to cluster peers on other hosts.
# But this is just a testing cluster.
# - "9095:9095" # Cluster IPFS Proxy endpoint
# - "9096:9096" # Cluster swarm endpoint
volumes:
- ./compose/cluster0:/data/ipfs-cluster
## Cluster PEER 1 ################################################################
# See Cluster PEER 0 for comments (all removed here and below)
ipfs1:
container_name: ipfs1
volumes:
- ./compose/ipfs1:/data/ipfs
cluster1:
container_name: cluster1
depends_on:
- ipfs1
environment:
CLUSTER_PEERNAME: cluster1
CLUSTER_IPFSHTTP_NODEMULTIADDRESS: /dns4/ipfs1/tcp/5001
volumes:
- ./compose/cluster1:/data/ipfs-cluster
## Cluster PEER 2 ################################################################
ipfs2:
container_name: ipfs2
volumes:
- ./compose/ipfs2:/data/ipfs
cluster2:
container_name: cluster2
depends_on:
- ipfs2
environment:
CLUSTER_PEERNAME: cluster2
CLUSTER_IPFSHTTP_NODEMULTIADDRESS: /dns4/ipfs2/tcp/5001
volumes:
- ./compose/cluster2:/data/ipfs-cluster
# For adding more peers, copy PEER 1 and rename things to ipfs2, cluster2.
# Keep bootstrapping to cluster0.
